LHG W60 - beamforming
Hi guys,
does anyone here know how to do beamforming with LHG60 wireless wire?
Also what RSSI should I get on 340m link with clear view?
Thank you
Clarify your question please. The device uses beamforming automatically, there is no need to “do it” yourself. Just point both devices in the general direction of each other, and the algorythm will work it’s magic by itself.
I’m no sure myself. We have done allignment in summer and we had RSSI about -56 but someone here said that we should be able to get much better signal for this distance.
we have experienced some disconnects during snow storms and I’m trying to get the best signal possible so this doesn’t happen again.
so maybe my question is this: Should we listen to allignment help or not ? ( I mean that 1,4 degree DOWN , 1 degree UP)
No listen to rssi
You should be fine in the range -48 to -50,
So you Are Not that fare away…
