LHG XL 52AC Disappointing Performance
We installed P2P with 2 LHG XL 52 AC but their performance is disappointing even with -55/-55 signal strength we are not even able to get 100 Mbps/ 100 Mbps and Mikrotik claims it supports up to 600 Mbps at a distance of 40 Kms plus and our distance is just 8 Kms with clear line of sight.
Mikrotik please respond why your LHG XL 52 AC is not able to give at least 300 Mbps if you claim 600 Mbps with 40 Kms range.
Post your wireless /export
Bridge device wireless export
jan/02/1970 08:44:30 by RouterOS 7.1.3
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-Ce country=no_country_set frequency=2437 frequency-mode=superchannel installation=outdoor mode=bridge
ssid=BSB-2192-P2P
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-Ceee country=no_country_set disabled=no frequency=5580 frequency-mode=superchannel mode=bridge
radio-name=RTK-TO-SATLOK skip-dfs-channels=all ssid=BSB-2192-P2P wireless-protocol=nstreme
/interface wireless nstreme
set wlan2 enable-nstreme=yes
Station Bridge wireless export
feb/28/2022 23:17:28 by RouterOS 7.1.3
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce
country=no_country_set frequency=auto frequency-mode=superchannel
installation=outdoor mode=station-bridge radio-name=SATLOK-ASHRAM ssid=
BSB-2192-P2P
country=no_country_set disabled=no frequency=auto frequency-mode=
superchannel installation=outdoor mode=station-bridge radio-name=
SATLOK-ASHRAM ssid=BSB-2192-P2P
Nowhere they say you will achieve actual “600 Mbps with 40 Kms range” it just says you will be able to establish connection up to 40km, i dont think such product even exist in this world,also dont mix connection rates and actual speed achievable.
From config all i can tell you this to try:
Dont use nstreme or nv2 on newer products,set it to 802.11 which gets me always much better perfomance.
Also set it AC only mode if you dont need N for some reason, and make sure that frequencies that you selected is actually clear, try other one to see if it works better due some reason like noise, and turn on Adaptivne noise immunity both sides under Advanced tab(Ap and Client)
With this device and such settings i get around 250mbit UDP and 150mbit TCP on 2.2km distance with lots of neighbour networks noise(ap scan shows 100+ APs)
