LHG XL 60Ghz home made
480m one side wAP60 inside LHG XL second side wAP60 inside JRC24 signal 75 MCS 8 sometimes 6
https://webshare.cz/#/group/33u784To2K/
Is it stable with rain? We have a link test 487m with similar solutions with 80 signal but we lost link with rain.
Rain is no problem link ok signal from 80 drop to 60 MSC from 8 to 6 but yesterday snow , one PTP wAP60G - JRC29 with wAP60G 320m heavy snow signal 80 no problem only when water snow on radom signal drop to 55 MCS 4 cleared radom signal 80. second P2P LHG XL with wAP60 - JRC 24 with wAP60G 450m LHG was very very snow covered signal drop to 0 no link after LHG cleansed from snow signal grow to 80 link ok I think that snowing or raining is no problem only when antenna or radom is covered with snow.
Nice tests but LHG and XL are not prepared for 60GHz, The construction isn’t stable…
We have final product, but actually not yet prepared, we complete other spare parts to start production :slight_smile:
Our product will cost 860 USD at now…
We accept orders. If anyone is interested in purchasing our product, please write to PM or email: office [at] multimediahd.pl
This is our test for 600m and 1000m with Iperf TX/RX on two laptops EliteBook with Core i7 and ProBook 6470b with Core i5:
https://trzepak.pl/viewtopic.php?p=480572#p480572
Kind Regards
Emil
do you have pictures of JRC assembly? I have a lot of spare JRCs…
JRC 24 https://webshare.cz/group/61E6u94rll/
JRC 29 https://webshare.cz/group/3N21hM40my/
thanks! I actually have 50+ antennas… not sure about those old single polarity feeders. I may try that.
the funny thing is that the board inside wAP60G says “LHG 60G”. at least mine inside the “wireless wire” box did so.
I´ve heard that it did not pass EIRP test in LHG so thats the reason why it isnt sold and it also wont be soon. It will be nice if someone from staff can confirm that.
yes i heard something like this too, seems like we don´t see LHG60 in Q1
it fits jrc24 extreme nicely. Too bad I have a lot of non extreme versions.
I tested that today… 185m one side is aimed to best signal, other site I just put there and hoped.
signal 80… cable speed…
Thanks for the tip MulderSK !
here https://webshare.cz/group/Cj27iJn2in/ wAP60G in parabola Maxlink 60cm better signal then JRC29 maybe focal distance whitch I tuned by the signal
The wavelength of 60Ghz compared to 5Ghz is so much smaller it just slips through the holes in the plastic LHG. So as a dish an LHG is not going to work for 60Ghz.
They should come with a LHG that has a metal laminate on the inside. This will work.
They will catch two flies at once. Because people living in snow fall regions can’t use the LHG’s since snow seems to build up very easy and once on even with a bit of sunlight takes time to melt away.
A metal dish take longer for snow to build up and also gets rid of the snow faster.
Price wise the extra thin metal layer won’t make such a big deal, its more the transport…
I work with Ignitenet links and with their big units, that is smaller then a LHG, I can already run links up to 600mtrs and a full Gb aggregated throughput. According their info they even have the same antenna unit with a 2,5Ghz aggregated unit that is capable of getting to 2,5Ghz.
And rain on my 600mtrs link? The link drops indeed in heavy downpours. But that happens here twice a year for 5 mins… and we have a 5Ghz backup still available…
Hi… I wanted to send a PM, but i am disabled or just blind. I´ve been googling your nick and found you on cz forum. It is easier for both of us… we dont have to write in english anymore…
expect PM there… :slight_smile:
