We are using several LHG’s in our network, and so far they have been working well. Today I was configuring one of them and ran into an issue. Once I do a basic configuration to it, I can no longer contact it in any way. All I can do is to reset to back to the stoneage and try again. I did take a backup from another identical unit, and plug it into this one and it works, but as soon as I change the IP address, I loose access to it, unless I leave the default 192.168.88.1. Does anyone have any ideas? Here is the working configuration that I put into it and have it work.
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=5ghz-a/n channel-width=
20/40mhz-eC country=“united states” disabled=no frequency=5200
installation=outdoor mode=bridge ssid=LtoD tx-power=30
tx-power-mode=all-rates-fixed wireless-protocol=802.11 wps-mode=disabled
add name=WAN
add name=LAN
/ip hotspot profile
add bridge=bridge1 interface=wlan1
add interface=ether1 list=WAN
add interface=wlan1 list=LAN
add address=10.220.1.102/24 interface=wlan1 network=10.220.1.0
set servers=1.1.1.1,8.8.8.8,71.10.216.1,1.0.0.1,8.8.4.4,71.10.216.2
add distance=1 gateway=10.220.1.1
/snmp
set contact=“user” enabled=yes location=company trap-generators=interfaces
trap-interfaces=all trap-version=2
/system clock
set time-zone-name=America/Detroit
/system identity
set name=LtoD
/system ntp client
set enabled=yes primary-ntp=10.220.1.50 secondary-ntp=10.250.1.42
Very basic. If I change 10.220.1.102 to 10.220.1.115 I loose all contact with it. Any direction would be very much appreciated.
I normally do that, and it still had problems. I have since run into this exact same issue on an SXTG-2hnd. Yet I know it is not the way I am doing it, because I have configured other SXT’s and mAP Lites, hAP lite’s and other Mikrotik products without issue. Both before and after this issue. I do my update downloads directly from Mikrotik, and I redownloaded them just in case there was an issue. No change.
Well, that is strange. What is the RouterOS version on that LHG?
In the production environment use only latest long-term version (at the moment 6.45.9).
Try to run “/system check-installation” and see what happens.
One more question - after you lose connectivity with that LHG have you tried to access it from another PC or Mikrotik router via L2 Winbox or mac-telnet?
If nothing of this helps then I would suggest contacting Mikrotik support with your exact configuration steps and supout file.
Sorry for taking so long to reply, been crazy busy. The installation was fine, I did try thru winbox thru the IP Address and thru the MAC address, although sometimes I could not even see those. I tried three different computers and a phone.
I did make some progress. Doing a manual reset allowed me to at least get into it. After that, I had to do a reset thru the System>Reset Configuration option, then when it rebooted, I did a remove configuration. After that, everything worked normally. Any other way resulted in a unit that was either partially or totally uncommunicative after configuring. Not sure what the deal is.
I’ve seen this happen when you add a wireless Interface that is set to mode=station into a bridge - be sure to set mode=station-bridge before adding it to the bridge. I note in this case mode=bridge so that should be fine..
I’ve also seen it happen when you use the scan function and then select an SSID with the connect button. It reverrts the wireless into mode=station
Not sure why this is doing what it is doing, but if I reset it with NO configuration, and then configure it from there, they work. And this did not affect just the LHG, but it also affected other Routerboard based devices.
