LHG5 Point to point setup Level 3 license
Hi!
I have two LHG5, I would like to setup point to point connection, IP is static.
Is it possible to make it with level 3 license, or I should buy level 4 license for it?
I dont really find any video about LHG5, I used SXT before (not the lite version) and it allowed me to put into ap bridge mode. LHG5 asking for higher license level…
So the main question is, Is it possible to configure point to point connection with the level 3 license? (1,5 km clear air is between the two LHG)
2 x1080P camera will be on one side, so I need the strong connection. I cant go with fc or utp, thats why I planned to use LHG5… on the another size LGH is connected to an ethernet switch…
https://i.mt.lv/cdn/product_files/LHG-seriesqg_190758.pdf
Says: The LHG is an outdoor wireless router with a built-in directional antenna. It can be used as a CPE or for point to
point links (use RouterOS wireless mode “bridge”
to work as a single-client AP for point to point scenarios).
Still looking how to manage to make it work (i used quick set to ptp ap and lost the connection to the equipment and is about 1000km away)
