LHG60 bridge - broadcast problem
Hello!
Hello everyone!
I’m trying to setup my LHG wireless bridge mode. I have two LHG60s , evereything is OK. We got a pure bridge with differents VLANs, and we have L2 connectivity in these VLANS.
But there’s a problem with broadcast packets (DHCP-BOOTP f.e.) on the main site (it’s in a bridge mode). It receives broadcasts (DHCP discovers) from the far end (station bridge mode) but it doesn’t forward them to ether1 interface.
add dhcp-snooping=yes fast-forward=no name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] mtu=1550
/interface w60g
set [ find ] disabled=no mode=bridge mtu=1550 name=wlan60-1 password=xxxxxxx ssid=XXX123
/interface w60g station
add mac-address=xx:xx:xx:xx mtu=1550 name=wlan60-station-1 parent=wlan60-1 put-in-bridge=bridge1 remote-address=xx:xx:xx:xx
/interface vlan
add interface=bridge1 name=mgmt vlan-id=5
add name=WAN
add name=LAN
/ip hotspot profile
add bridge=bridge1 interface=wlan60-1
add bridge=bridge1 interface=ether1 trusted=yes
add bridge=bridge1 interface=wlan60-station-1 trusted=yes
/interface bridge vlan
add tagged=ether1 untagged=wlan60-1 vlan-ids=5
add interface=wlan60-1 list=WAN
add interface=ether1 list=LAN
  • VLAN 5 is management
But everything is OK at the far side. Broadcasts packets can go from wlan60 to ether1 and back.
What I’m doing wrong?
From your decription I figure there are two devices involved … but your posting is … blunt … from which one?
and whats the problem with a little sketch, to let the “free-of-charge-supporters” know, what you are created over there ? … is this too much ? … it .. isn’t too much !
end of kidding:
give us at least a “/export verbose hide-sensitive” of the both of your devices …
and … it is best practise … and a display of good will …: a sketch of the intended L2 and L3-Design
… you can pay a thousands of dollars for support in “BIG-BIZ”-vendors … …and no answer will be received, if you do not deliver basic points about your issue and your (maybe-at-the-time-not-so)-network !
improve.
OK, sorry.
I thought I was clear)))
Here’s a little sketch.
We have two LHG60. This is the last mile of a QinQ channel (service tag 405).
LHG60 #1 (Ant1) works as a bridge and LHG60 #2 (Ant2) works as a station-bridge
LAN1 <—> ether1<—>Ant2 (LHG60 #2) <–WLAN60–>Ant1(LHG60#1)-ether1-LAN2 (DHCP server)
As a result we have a L2 connectivity of the whole channel. We use different VLANs. Everything is OK with static IPs in LAN1. But we use DHCP addresses. The problem is that Ant1 doesn’t send broadcast packets to Ether1.
If a host from LAN1 (f.e. VLAN 200) sends DHCP DISCOVER, it passes through wireless bridge to Ant1 and it drops this request. We see these broadcasts at wlan60-station-1 interface of Ant1, but it drops them and we can’t see broadcasts at ether1.
Though ARP broadcasts pass through Ant1 to Ant2.
Ant1
# model = RBLHGG-60ad
add ageing-time=5m arp=enabled arp-timeout=auto auto-mac=yes dhcp-snooping=no disabled=no fast-forward=no igmp-snooping=no mtu=auto name=bridge1 protocol-mode=none vlan-filtering=no
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no \
    full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=48:8F:5A:4D:7A:C6 mtu=1598 name=ether1 orig-mac-address=\
    48:8F:5A:4D:7A:C6 rx-flow-control=off speed=1Gbps tx-flow-control=off
/queue interface
set bridge1 queue=no-queue
/interface w60g
set [ find ] arp=enabled arp-timeout=auto disabled=no frequency=auto isolate-stations=yes l2mtu=1600 mac-address=48:8F:5A:4D:7A:C7 mode=bridge mtu=1598 name=wlan60-1 put-stations-in-bridge=none \
    region=no-region-set !scan-list ssid=SSID tx-sector=auto
add arp=enabled arp-timeout=auto disabled=no mac-address=48:8F:5A:4D:7A:C7 mtu=1598 name=wlan60-station-1 parent=wlan60-1 put-in-bridge=bridge1 remote-address=48:8F:5A:24:3D:F4
/interface vlan
add arp=enabled arp-timeout=auto disabled=no interface=bridge1 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mtu=1598 name=vlan4 use-service-tag=no vlan-id=5
/queue interface
set vlan4 queue=no-queue
/interface ethernet switch
set 0 cpu-flow-control=yes mirror-source=none mirror-target=none name=switch1
set 0 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 1 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set [ find name=all ] comment="contains all interfaces" exclude="" include="" name=all
set [ find name=none ] comment="contains no interfaces" exclude="" include="" name=none
set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" include="" name=dynamic
add exclude="" include="" name=WAN
add exclude="" include="" name=LAN
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet default-route-distance=2 name=default use-peer-dns=yes
set [ find default=yes ] authentication-types="" disable-pmkid=no eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m interim-update=0s management-protection=disabled mode=none \
    mschapv2-username="" name=default radius-called-format=mac:ssid radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=\
    XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-sta-private-algo=none static-transmit-key=key-0 \
    supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=aes-ccm
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value="0xff\$(CLIENT_DUID)"
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=flash/hotspot html-directory-override="" http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=\
    default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none !insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=default !parent-queue !queue-type shared-users=\
    1 status-autorefresh=1m transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no use-responder-dns=exclusively
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048,modp1024 dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=aes-128,3des hash-algorithm=sha1 lifetime=1d name=default nat-traversal=yes \
    proposal-check=obey
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=modp1024
/ppp profile
set *0 address-list="" !bridge !bridge-horizon !bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter !insert-queue-before !interface-list \
    !local-address name=default on-down="" on-up="" only-one=default !outgoing-filter !parent-queue !queue-type !rate-limit !remote-address !session-timeout use-compression=default \
    use-encryption=default use-mpls=default use-upnp=default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-horizon !bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter !insert-queue-before !interface-list \
    !local-address name=default-encryption on-down="" on-up="" only-one=default !outgoing-filter !parent-queue !queue-type !rate-limit !remote-address !session-timeout use-compression=default \
    use-encryption=yes use-mpls=default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB \
    pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB \
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set wlan60-1 queue=wireless-default
set wlan60-station-1 queue=wireless-default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id !confederation disabled=no ignore-as-path-len=no name=default out-filter="" redistribute-connected=no redistribute-ospf=no \
    redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id !domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 \
    metric-static=20 !mpls-te-area !mpls-te-router-id name=default out-filter=ospf-out redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0 !routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=backbone type=default
/snmp community
set [ find default=yes ] addresses=::/0 authentication-protocol=MD5 disabled=no encryption-protocol=DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=flash/log disk-lines-per-file=1000 disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=bsd-syslog target=remote
/user group
set read name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude skin=default
set write name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude skin=default
set full name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp skin=default
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path="" require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=no crl-store=ram crl-use=no
add auto-isolate=no bpdu-guard=no bridge=bridge1 broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=ether1 \
    internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=yes \
    unknown-multicast-flood=yes unknown-unicast-flood=yes
add auto-isolate=no bpdu-guard=no bridge=bridge1 broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=no interface=wlan60-station-1 \
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
    tcp-last-ack-timeout=10s tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m udp-stream-timeout=3m udp-timeout=10s
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes max-neighbor-entries=8192 route-cache=yes rp-filter=no \
    secure-redirects=yes send-redirects=yes tcp-syncookies=no
add disabled=no tagged=ether1 untagged=wlan60-1 vlan-ids=5
/interface detect-internet
set detect-interface-list=none internet-interface-list=none lan-interface-list=none wan-interface-list=none
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2 caller-id-type=ip-address default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 \
    max-sessions=unlimited mrru=disabled one-session-per-host=no use-ipsec=no
add disabled=no interface=wlan60-1 list=WAN
add disabled=no interface=ether1 list=LAN
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:76:A8:3A:05:42 max-mtu=1598 mode=ip netmask=24 port=1194 \
    require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500 max-mtu=1598 mrru=disabled pfs=no port=443 \
    tls-version=any verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" caps-man-names="" certificate=none discovery-interfaces="" enabled=no interfaces="" lock-to-caps-man=no static-virtual=\
    no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.26.0.26/24 disabled=no interface=vlan5 network=10.26.0.0
/ip cloud
set ddns-enabled=no ddns-update-interval=none update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-server config
set accounting=yes interim-update=0s store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB max-concurrent-queries=100 max-concurrent-tcp-sessions=20 max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=\
    10s servers="" use-doh-server="" verify-doh-cert=no
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users" disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=all src-address=::/0 template=yes
/ip ipsec settings
set accounting=yes interim-update=0s xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no max-cache-object-size=2048KiB max-cache-size=unlimited \
    max-client-connections=600 max-fresh-time=3d max-server-connections=600 parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no src-address=::
add !bgp-as-path !bgp-atomic-aggregate !bgp-communities !bgp-local-pref !bgp-med !bgp-origin !bgp-prepend !check-gateway disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.26.0.1 \
    !route-tag !routing-mark scope=30 target-scope=10
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443 tls-version=any
set api address="" disabled=no port=8728
set winbox address="" disabled=no port=8291
set api-ssl address="" certificate=none disabled=no port=8729 tls-version=any
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/flash/pub disabled=no max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set auth-method=none connection-idle-timeout=2m enabled=no max-connections=200 port=1080 version=4
/ip ssh
set allow-none-crypto=no always-allow-password-login=no forwarding-enabled=no host-key-size=2048 strong-crypto=no
/ip tftp settings
set max-block-size=4096
/ip traffic-flow
set active-flow-timeout=30m cache-entries=64k enabled=no inactive-flow-timeout=15s interfaces=all
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes igmp-type=yes in-interface=yes ip-header-length=\
    yes ip-total-length=yes ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=yes nat-dst-port=yes nat-src-address=yes nat-src-port=yes out-interface=yes packets=yes \
    protocol=yes src-address=yes src-address-mask=yes src-mac-address=yes src-port=yes tcp-ack-num=yes tcp-flags=yes tcp-seq-num=yes tcp-window-size=yes tos=yes ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway origination-interval=5s preferred-gateway=0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no redistribute-connected=no redistribute-ospf=no \
    redistribute-static=no routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-community=public trap-generators=temp-exception trap-target="" trap-version=1
/system clock
set time-zone-autodetect=yes time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=Ant1
/system leds
set 0 disabled=no interface=wlan60-1 leds=led1 type=wireless-signal-strength
set 1 disabled=no interface=wlan60-1 leds=led2 type=align-left
set 2 disabled=no interface=wlan60-1 leds=led3 type=align-right
set 3 disabled=no interface=wlan60-1 leds=led4 type=align-down
set 4 disabled=no interface=wlan60-1 leds=led5 type=align-up
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=debug
add action=memory disabled=no prefix="" topics=dhcp
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0 server-dns-names=""
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
/system resource irq rps
set ether1 disabled=yes
/system routerboard settings
set auto-upgrade=no boot-device=nand-if-fail-then-ethernet boot-protocol=bootp protected-routerboot=disabled reformat-hold-button=20s reformat-hold-button-max=10m silent-boot=no
/system routerboard reset-button
set enabled=no hold-time=0s..1m on-event=""
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes ping-start-after-boot=5m ping-timeout=1m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> port=25 start-tls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set allowed-interface-list=all
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
/tool sms
set allowed-number="" auto-erase=no channel=0 port=none receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name=Ant1_cap filter-cpu="" filter-direction=any filter-interface=wlan60-station-1 filter-ip-address="" filter-ip-protocol="" filter-ipv6-address="" \
    filter-mac-address="" filter-mac-protocol="" filter-operator-between-entries=or filter-port="" filter-size="" filter-stream=no memory-limit=1000KiB memory-scroll=yes only-headers=no \
    streaming-enabled=no streaming-server=0.0.0.0:37008
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=no stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s use-radius=no
Ant2
add add-dhcp-option82=no ageing-time=5m arp=enabled arp-timeout=auto auto-mac=yes dhcp-snooping=yes disabled=no ether-type=0x8100 fast-forward=no frame-types=admit-all igmp-snooping=no \
    ingress-filtering=no mtu=auto name=bridge1 protocol-mode=none pvid=1 vlan-filtering=yes
add add-dhcp-option82=no ageing-time=5m arp=enabled arp-timeout=auto auto-mac=yes dhcp-snooping=yes disabled=no fast-forward=no forward-delay=15s igmp-snooping=no max-message-age=20s mtu=auto \
    name=bridge2 priority=0x8000 protocol-mode=rstp transmit-hold-count=6 vlan-filtering=no
    full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=48:8F:5A:24:3D:F3 mtu=1598 name=ether1 orig-mac-address=\
    48:8F:5A:24:3D:F3 rx-flow-control=off speed=1Gbps tx-flow-control=off
/queue interface
set bridge2 queue=no-queue
/interface w60g
set [ find ] arp=enabled arp-timeout=auto disabled=no frequency=auto isolate-stations=yes l2mtu=1600 mac-address=48:8F:5A:24:3D:F4 mode=station-bridge mtu=1598 name=wlan60-1 \
    put-stations-in-bridge=none region=no-region-set !scan-list ssid=SSID tx-sector=auto
/interface vlan
add arp=enabled arp-timeout=auto disabled=no interface=wlan60-1 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mtu=1598 name=vlan5 use-service-tag=no vlan-id=5
/queue interface
set vlan5 queue=no-queue
/interface lte apn
/ip hotspot profile
/ip ipsec profile
    proposal-check=obey
/ip ipsec proposal
/ppp profile
/queue type
/queue interface
/routing ospf area
/snmp community
/user group
/caps-man aaa
/caps-man manager
    internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=405 restricted-role=no restricted-tcn=no tag-stacking=yes trusted=yes \
add auto-isolate=no bpdu-guard=no bridge=bridge1 broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=no interface=wlan60-1 \
/ip settings
add bridge=bridge1 disabled=no tagged=wlan60-1 untagged=ether1 vlan-ids=405
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:22:54:AF:D2:6C max-mtu=1500 mode=ip netmask=24 port=1194 \
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=disabled pfs=no port=443 \
    no
/ip accounting
add address=10.26.0.25/24 disabled=no interface=vlan5 network=10.26.0.0
/ip cloud
/ip cloud advanced
/ip hotspot user
/ip ipsec policy
/ip ipsec settings
/ip proxy
/ip service
/ip smb
/ip smb shares
/ip smb users
/ip socks
/ip ssh
/ip tftp settings
/ip traffic-flow
/ip upnp
/mpls
/mpls interface
/mpls ldp
/port firmware
/ppp aaa
/radius incoming
/routing mme
/routing rip
/snmp
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Moscow
/system identity
set name=Ant2
/system leds
/system logging
/system note
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
/system watchdog
/tool e-mail
/tool graphing
/tool mac-server
set enabled=yes
/tool romon
/tool romon port
/tool sms
/tool sniffer
set file-limit=1000KiB file-name=Ant2_cap filter-cpu="" filter-direction=any filter-interface=wlan60-1 filter-ip-address="" filter-ip-protocol="" filter-ipv6-address="" filter-mac-address="" \
    filter-mac-protocol="" filter-operator-between-entries=or filter-port="" filter-size="" filter-stream=no memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=no \
/user aaa
Hi, did you manage to solve this? I have the same problem, I need to pass a dhcp between routers until the last one but it doesn’t
