LHGG lock to specific channel?
So I recently bought LHGG kit. From this particular tower that the router is aimed at I can get LTE Bands 1,3,20 because I’m 4.5km away from and theres some trees between. According to this
LHGG cannot do 1+3 or 3+1. So it either connects to 1+20 which during the day often sucks or 3+3. Now 3+3 is usually ok, but for some reason it doesn’t hold onto it properly. Like it switches primary band to band 3@5MHz and CA band to band3@20MHz. Is it possible to lock primary to band 3@20Mhz? Cause when it automatically switches to this, the internet speed doesn’t drop below 30 and is overall stable.
https://wiki.mikrotik.com/wiki/Manual:Interface/LTE#Using_Cell_lock
This select a primary band
atcell=2,3,earfcn ← FreqLock
at
cell=1,3,earfcn,phy-cellid ← CellLock
Second is automaticaly added if possible.
So I followed the guide to lock it to B3@20MHz. Now I’m having a problem that it loses connection or something - the internet stops working. It still shows that its connected to the primary band(B3@20MHz). Used this http://forum.mikrotik.com/t/r11e-lte6-2ca-not-staying-connected/136004/1 guide to log stuff and the internet cuts out exactly at the moment when it reconnects B3@5MHz as CA band. I mean it doesn’t do it every time when it connects it as CA band but only sometimes. I have to reset the lte modem or reboot the whole device to bring it back to life. If I disable the frequency lock, it uses B3@5MHz as primary band. Any ideas why this happens? Is this a bug of ROS or something at the cell tower not liking me due to locking to a channel?
I was searcing the forum for problems like the ones I am experincing and found this topic.
I have another device, it is the WAP KIT LTE cat6 and I have the very same problems.
I got these Mikrotik units just because I need cell lock.
If the modem is free to connect by itself, then it connects to a specific tower and it works
If I lock the modem to the very same cell, it connects, but no internet at all
I upgraded both the router OS and the modem firmware, but no improvements.
Any ideas?
