LHGG Login issue
Hi all, I have a problem with my LHGG.
I can no longer log in either via winbox, web, or ssh.
I’ve tried resetting it several times, and as soon as I reset it I can log in via winbox, but after setting it up if I reboot, again I can’t log in.
It also happens just by logging off from winbox, if I try to log in again I can’t.
I also tried loading an older firmware with netinstall, but the result is the same, after a reboot the LHGG is no longer accessible.
Do you have any ideas?
Connect to winbox by MAC
That’s the first thing I tried.. No luck
So you are blocking access to the device when setting up
