LHGG LTE6 to Unifi UDM Pro WAN port
Hi All,
I’m hoping someone can help me out as I’ve spent the last two days pulling my hair out with this. I have a UDM PRO and a LHGG LTE6. I want to be able to connect it directly the the WAN port on the UDM but I’ve been unsuccessful. I’ve followed the guide exactly as I understand it in relation to creating a clan etc but it doesn’t work and the UDM reports no IP address. I’m not sure if this is because the guide refers to getting it working in a slightly different setup though. I have tested the LHGG directly connected to a laptop in its default state and that’s getting internet fine. I have tried the LHGG connected directly into the UDM WAN port using a POE injector but no luck. I’ve tried to a different port on the UDM and then taken a second cable from a spare port to the WAN but no luck.
Lastly I tried connecting to by UniFi 24 port POE switch directly and then a LAN cable from that to the UDM WAN but again nothing.
I would really appreciate any assistance as I don’t know what else to try or check now and fear I might have wasted some money otherwise.
Many thanks
I am considering purchasing the LHGG LTE6 also and would be using it in a similar setup as what you have described. Have you been able to get it to work at all?
