librouteros problem
i am testing librouteros in a linux server, using collectd to graph a mikrotik server
The problem i have is i success graph CPU, Memory and DF, but Interfaces is not working, collectd makes emptys graphs, after checking with the script "ros" i get this :
./ros -u warn1ng 10.0.0.58 interface
Type: pppoe-in
Comment: (null)
Bytes: 0 / 0
Packets: 0 / 0
Errors: 0 / 0
Drops: 0 / 0
MTU: 1480
L2 MTU: 0
Running: true
Dynamic: true
Enabled: true
Type: pppoe-in
Comment: (null)
Bytes: 0 / 0
Packets: 0 / 0
Errors: 0 / 0
Drops: 0 / 0
MTU: 1492
L2 MTU: 0
Running: true
Dynamic: true
Enabled: true
Dunno why i am getting 0 stats, on all the interfaces (like 500 interfaces if i count the pppoe ones)
What i am Running is:
Collectd version 5.1.0
Librouteros version 1.1.2
Mikrotik Routerboard server version 5.19 x86
Sorry my bad english.
Perhaps between 2010 and now, RouterOS changed something in the interfaces, while the “ros” executable is doing more than a simple print, and is thus not coping with the new changes…
Try to use low(er) level commands, e.g.
./ros -u warn1ng 10.0.0.58 /interface/print
Works incorrectly with CCR + ROS 6.x
In collectd, SFP interfaces are not graphed at all.
DfComplex and Memory have strange values (3.5T free, 360G used)
All other graphs are empty.
Crossposted to http://forum.mikrotik.com/t/collectd-plugin-routeros-on-the-horizon/33459/4
Collectd correctly displays “eth*” interface names on graphs, but all graphs still empty:
ros -u collectd 10.70.59.1 /interface/print
Password for user collectd:
Status: re
  Param 0: .id = *F
  Param 1: name = ether01_LAN
  Param 2: default-name = ether1
  Param 3: type = ether
  Param 4: mtu = 1500
  Param 5: l2mtu = 1590
  Param 6: max-l2mtu = 10226
  Param 7: mac-address = D4:CA:6D:AC:E1:A4
  Param 8: fast-path = true
  Param 9: rx-byte = 0
  Param 10: tx-byte = 0
  Param 11: rx-packet = 0
  Param 12: tx-packet = 0
  Param 13: rx-drop = 0
  Param 14: tx-drop = 0
  Param 15: rx-error = 0
  Param 16: tx-error = 0
  Param 17: running = false
  Param 18: slave = true
  Param 19: disabled = true
Status: re
  Param 0: .id = *10
  Param 1: name = ether02_LAN
  Param 2: default-name = ether2
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:A5
Status: re
  Param 0: .id = *11
  Param 1: name = ether03_LAN
  Param 2: default-name = ether3
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:A6
Status: re
  Param 0: .id = *12
  Param 1: name = ether04_LAN
  Param 2: default-name = ether4
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:A7
  Param 9: rx-byte = 22475761
  Param 10: tx-byte = 418094497
  Param 11: rx-packet = 143888
  Param 12: tx-packet = 324924
  Param 17: running = true
  Param 19: disabled = false
Status: re
  Param 0: .id = *13
  Param 1: name = ether05_LAN
  Param 2: default-name = ether5
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:A8
  Param 9: rx-byte = 356395444712
  Param 10: tx-byte = 48596693134
  Param 11: rx-packet = 685974862
  Param 12: tx-packet = 609338823
Status: re
  Param 0: .id = *14
  Param 1: name = ether06_LAN
  Param 2: default-name = ether6
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:A9
  Param 9: rx-byte = 264152870004
  Param 10: tx-byte = 53936499555
  Param 11: rx-packet = 719514605
  Param 12: tx-packet = 691531130
Status: re
  Param 0: .id = *15
  Param 1: name = ether07_LAN
  Param 2: default-name = ether7
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:AA
  Param 9: rx-byte = 146900634331
  Param 10: tx-byte = 30481556029
  Param 11: rx-packet = 409007180
  Param 12: tx-packet = 390219318
Status: re
  Param 0: .id = *16
  Param 1: name = ether08_LAN
  Param 2: default-name = ether8
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:AB
  Param 9: rx-byte = 218856709717
  Param 10: tx-byte = 47879654073
  Param 11: rx-packet = 633436637
  Param 12: tx-packet = 607387093
Status: re
  Param 0: .id = *17
  Param 1: name = ether09_LAN
  Param 2: default-name = ether9
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:AC
  Param 9: rx-byte = 447860895429
  Param 10: tx-byte = 69233856522
  Param 11: rx-packet = 939517709
  Param 12: tx-packet = 887465285
Status: re
  Param 0: .id = *18
  Param 1: name = ether10_LAN
  Param 2: default-name = ether10
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:AD
  Param 9: rx-byte = 431504627163
  Param 10: tx-byte = 63614709989
  Param 11: rx-packet = 872832678
  Param 12: tx-packet = 807329985
Status: re
  Param 0: .id = *19
  Param 1: name = ether11_LAN
  Param 2: default-name = ether11
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:AE
  Param 9: rx-byte = 195302575489
  Param 10: tx-byte = 21441921136
  Param 11: rx-packet = 171273971
  Param 12: tx-packet = 123160019
Status: re
  Param 0: .id = *1A
  Param 1: name = ether12_WAN
  Param 2: default-name = ether12
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:AF
  Param 9: rx-byte = 342010995001
  Param 10: tx-byte = 2059177914381
  Param 11: rx-packet = 4110351222
  Param 12: tx-packet = 4424968198
  Param 18: disabled = false
Status: re
  Param 0: .id = *B
  Param 1: name = sfp1
  Param 2: default-name = sfp1
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:A0
  Param 18: disabled = true
Status: re
  Param 0: .id = *C
  Param 1: name = sfp2
  Param 2: default-name = sfp2
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:A1
Status: re
  Param 0: .id = *D
  Param 1: name = sfp3
  Param 2: default-name = sfp3
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:A2
Status: re
  Param 0: .id = *E
  Param 1: name = sfp4
  Param 2: default-name = sfp4
  Param 4: mtu = 1500
  Param 7: mac-address = D4:CA:6D:AC:E1:A3
Status: re
  Param 0: .id = *9
  Param 1: name = LANs
  Param 2: type = bridge
  Param 3: mtu = 1500
  Param 4: l2mtu = 1590
  Param 5: mac-address = D4:CA:6D:AC:E1:AE
  Param 6: fast-path = false
  Param 7: rx-byte = 1986184929974
  Param 8: tx-byte = 334517187333
  Param 9: rx-packet = 4394982897
  Param 10: tx-packet = 4108226360
  Param 11: rx-drop = 0
  Param 12: tx-drop = 0
  Param 13: rx-error = 0
  Param 14: tx-error = 0
  Param 15: running = true
  Param 16: disabled = false
Status: done
API command:
/interface/ethernet/print
=stats=
example of result for 1 interface form RB2011
<<< /interface/ethernet/print
<<< =stats=
>>> !re
>>> =.id=*2
>>> =name=ether1
>>> =default-name=ether1
>>> =mtu=1500
>>> =l2mtu=1598
>>> =mac-address=D4:CA:6D:86:E1:85
>>> =orig-mac-address=D4:CA:6D:86:E1:85
>>> =arp=enabled
>>> =auto-negotiation=true
>>> =full-duplex=true
>>> =speed=100Mbps
>>> =master-port=none
>>> =bandwidth=unlimited/unlimited
>>> =switch=switch1
>>> =poe-out=auto-on
>>> =poe-priority=10
>>> =driver-rx-byte=62470600
>>> =driver-rx-packet=269966
>>> =driver-tx-byte=60176282
>>> =driver-tx-packet=106563
>>> =rx-bytes=63550137
>>> =rx-too-short=0
>>> =rx-64=64346
>>> =rx-65-127=115497
>>> =rx-128-255=51012
>>> =rx-256-511=10619
>>> =rx-512-1023=4434
>>> =rx-1024-1518=24054
>>> =rx-1519-max=0
>>> =rx-too-long=0
>>> =rx-broadcast=113466
>>> =rx-pause=0
>>> =rx-multicast=69227
>>> =rx-fcs-error=0
>>> =rx-align-error=0
>>> =rx-fragment=0
>>> =rx-overflow=0
>>> =tx-bytes=60389574
>>> =tx-64=7154
>>> =tx-65-127=53886
>>> =tx-128-255=5658
>>> =tx-256-511=2714
>>> =tx-512-1023=2616
>>> =tx-1024-1518=34528
>>> =tx-1519-max=0
>>> =tx-too-long=0
>>> =tx-broadcast=831
>>> =tx-pause=0
>>> =tx-multicast=448
>>> =tx-underrun=0
>>> =tx-collision=0
>>> =tx-excessive-collision=0
>>> =tx-multiple-collision=0
>>> =tx-single-collision=0
>>> =tx-excessive-deferred=0
>>> =tx-deferred=0
>>> =tx-late-collision=0
>>> =running=true
>>> =disabled=false
