Hi all.
is it possible to purchase a licence and upgrade a RB411 to level4 ?
Thanks in advance
Hi all.
Thanks in advance
yes but i assume the 411 already has a licence yea? so it would just be an upgrade ?
You can change it. It is technically not an “upgrade”.
http://wiki.mikrotik.com/wiki/Manual:License#Change_license_Level
Hi Yes it has level 3 at the moment.
Thank you for your answers
You will not receive any discount, so you will need to purchase a L4 license for full price. Normally it is much cheaper to just purchase correct RouterBOARD model:
http://routerboard.com/RB411GL
http://routerboard.com/RB411AH
Thx Normis. Unfortunately this RB is up a tower. Was just used for scanning the air, Now I want to change it to an AP.
Dont fancy the climb so going to buy new Licence ![]()
