license - info , help
i have about 20 rb 500 , and 112 , that have license lvl 4
upgrade until 1 dec 2006 , or 1 jan 2007 ,
ofcourse cant upgrade to 2.9.42
they are 2.9.23 , 2.9.10 , 2.9.2
need new license or what ?
i hope i dont need to buy new license …
how to upgrade ?
you need to run netinstall…
You can upgrade to any 2.9.x version, but if the license is expired you cannot upgrade remotely.
You have to upgrade using netinstall as Alex said.
Bye,
Ricky
to clarify, using Netinstall is required due to the following fact - we have changed the licensing terms, and now there is no more upgrade time limit BUT (!) your old version does not know about the licensing changes, so you have to TEACH it by using Netinstall.
if Netinstall is not an option, you must act according to the old licensing terms - if license expired, you would be required to get a new one (buy it).
