License not showing on x86
Greetings to all ! After purchasing a license key for a x86 router OS, and entered through Winbox / system / License , restarted the router but nothing shows there .
Does it take some time (hours) for Mikrotik to activate something ? Also my order shows fine on MT portal account , but when I click “All CHR keys” no keys show there either !
P.S. Software ID was entered accurately .
Any help would be appreciated
All CHR keys?
x86 is one product, CHR is another, contact support
True ! Too much speed ! :frowning:
When installing a x86 CD .iso through VMware (as I have done) on a remote server is there any difference from choosing the VMDK image in regard to the router (to do the same thing), as to the operation/capabilities of the router ?
They are identical files, only the licensing changes.
Using x86 on virtualized environment makes no sense.
Thank you !
Yes indeed to the second part ! Like I said too fast of a click , too tired when did that, and didn’t pay any attention to the obvious. The intention is to move that router (from that machine) in a month, to another machine so I may have to buy a new license (I have contacted support) …
