License on vdi or vhd
Welcome, will soft id change if I move vdi or vhd file with mikrotik routeros on other pc?
You can only try it out but as I am informed it would not change, but it is more then a license fee question that muist also match.
It will just change if Hard drive change. All other changes in hw, is irrelevant. Licence is related to hd, and a viritual hd, can be moved around different vm’s - To do it leagl - have one licence for each HD.
In old times - you buy routeros as a flashdrive fitting to IDE Connector on x86 systems.
