Hi all,
I bought a mANTBox 2 12s and comes with a L3 license and in your web page says that it comes with L4 license. I can´t contigure it in AP mode. ![]()
A screenshoot:
This have a solution?
Regards.
Hi all,
A screenshoot:
Regards.
Photo of the AP.
Regards.
I would suggest to contact support directly. Forum is user driven mostly.
Solved.
Best regards.
Sorry for waking up a dead thread, but I have the same problem.
Did you get an upgrade ?
Wayne
Yes, solved by direct Mikrotik support.
Regards.
