License problem!
I have RB 433 with OS 3.13 few minutes ago i had upgraded software to 3.30 it was necessary. Anyway after booting procedure i get the following message:
“You have 23h18m to configure the router to be remotely accessible,
and to enter the key by pasting it in a Telnet window or in Winbox.
See www.mikrotik.com/key for more details.”
I inform you that i had previously update license key and i got the message that license key is already up to date! I also upgraded the firmware to 2.20 and still the same problem!
I would a appreciate any help since i got only 23 hours left. And this one is one of my core routers with all the settings inside!
Thanks in advance
Log into your Mikrotik account and ‘search’ for the key if you bought it directly from Mikrotik or ‘request key’ if you bought the routerboard from a dealer or distributor. You do this using the software_ID.
Then go to the license, copy it, and paste it into your routerboard under ‘Software License.’
If you can’t get an account set up within 24 hours, send the serial number and Software_ID to your Mikrotik dealer and ask them for help. They should be able to retrieve and send you the license.
Tom
I did as you said and it helped!
Thank you :slight_smile:
