License problem
Hello Mikrotik support…
Got license key from Your reseller: http://www.eurodk.com/ . The problem is that i cannot use it, cause the purchase procedure takes more than 24h from the point of the first time installation, so the PC shuts down before i can log in through the winbox to paste the key. The paltform is x86, soft id. - 83MZ-M9VL and the license (l4):
-----BEGIN MIKROTIK SOFTWARE KEY------------
9hT1y0tOor2vBPCqf+Pj5Y7BondWZq4Qp/nAkgWOqpHr
l/cp4RzeyQMAHObH6FyOc9rmoLTSP0KUGdznuZLDDA==
-----END MIKROTIK SOFTWARE KEY--------------
I know that i can reinstall the mikrotik OS, but then i lose the software id, also the license…
How can i solve the problem
Kind Regards
Aleksander
Try to use netinstall first. Soft id couldn;t change.
