Hi, I’m running L6 3.13 on 'n AMD64+ 2.2ghz, 1GB DDR2 800, 120 GB SATA HDD, which I bought when I started up my network. However, I noticed in a few hours since installation that this specifications is way more than needed for RouterOS, especially on a smallish network. I’ve got another computer, 1.1 AMD Thunderbird, 512MB PC133, 80 GB.
Would like to know if it is possible that I can transfer the L6 license over so that I can use the fast computer for something else.
In the FAQ it says I have to use the same hard drive, but the Thunderbird does not support SATA.
Is it possible? and can someone assist me if it is. Thanks
hi,
i saw ur post.can try to ghost the hard disk using another hard disk dat is not sata.give it a try.
krising.let me know if it works. try norton ghost 9.0
Someone I doubt that will work, since ghosting doesn’t copy your Harddrives model number. Otherwise you would have seen a lot of other people ghosting their LEVEL6 license to multiple HDD’s.
