license upgrades
I know that I’m jumping the gun on this, but my entire wisp is MT and Ubiquity. I have over 200 rb133c clients that state they are upgradable to 3.0
when 4.0 is in the works is there any special pricing to do a mass upgrade?
you can either keep using 3.9 (for example) or get a new license for 4.0
This is ouch! Unless there will be a significant changes to justify it.
My 2 cents…
JFYI v3 could last up until 3.99, the last number is never known.
In v4, will it be able to make coffee yet?
:open_mouth:
it can already … you need to make some kind of script that triggers the serial port where you could have a switch to turn on the coffee maker …
aaaha, but there is limitations!
You actually need to prep the machine by putting in the coffee.
& You have to add the milk + sugar manually.
Not acceptable!
:smiley:
To be honest i didn’t expect a reply on that one…
