I have just installed a Level 4 License of RouterOS, but when I try to select AP Bridge Mode I get the following Error, I already had a license but because of this error was not sure if I have the correct license so I brought another license.
Can anyone help me out here.
The error is “Coudn’t Change Interface - License does not allow AP Mode”
So when you type “/system license print” it does show level 4 correct? Have you rebooted the system since you put on the new license to make sure it took effect?
Normis - Reply with assitance (support) is what I ment
marko_bg - I already have a Level 4 license , should not have to buy another license to get this going, the isssue is some thing is wrong with my installation I suspect.
