Hi
i have a PC and X86 is installed on it. but after updated it , it not booted up. I had one backup from X86. now if i format PC and reinstall x86 on device(PC), do it will be loss your license or return license it?
tnx a lot for respondig.
Do you mean taht you have Mikrotik’s ROS x86 installed on this PC? We are not mentalists to know what do you want to say.
yes, i mean it.
i did it but not detected my mikrotik in Netinstall. Do you have any way for resolve this problem?
I’ve never tried Netinstall with x86 machine, so I can’t say if it really works. You’d need to enable network boot and then it should/could. Installation from CD should be more reliable.
I bought RB4011iGS + RM, that's the license problem, what should I do?
MikroTik RouterOS 6.43.4 (c) 1999-2018 http://www.mikrotik.com/
ROUTER HAS NO SOFTWARE KEY
You have 21h27m to configure the router to be remotely accessible,
and to enter the key by pasting it in a Telnet window or in Winbox.
Turn off the device to stop the timer.
See www.mikrotik.com/key for more details.
Current installation "software ID": CSJ3-VV0F
Please press "Enter" to continue!
[admin@MikroTik] > /system license print
software-id: CSJ3-VV0F
expires-in: 21h26m4s
[admin@MikroTik] > /system routerboard print
routerboard: yes
model: RB4011iGS+
serial-number: AAAF09821F30
firmware-type: al2
factory-firmware: 6.43.4
current-firmware: 6.43.4
upgrade-firmware: 6.43.4
