license
currently using RB450G
jan/01/1970 08:00:06 system,info verified user-manager-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of user-manager-5.7
jan/01/2002 09:00:01 system,info verified system-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of system-5.7
jan/01/2002 09:00:01 system,info verified security-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of security-5.7
jan/01/2002 09:00:01 system,info verified routing-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of routing-5.7
jan/01/2002 09:00:01 system,info verified routerboard-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of routerboard-5.7
jan/01/2002 09:00:01 system,info verified ppp-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of ppp-5.7
jan/01/2002 09:00:01 system,info verified ntp-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of ntp-5.7
jan/01/2002 09:00:01 system,info verified multicast-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of multicast-5.7
jan/01/2002 09:00:01 system,info verified mpls-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of mpls-5.7
jan/01/2002 09:00:01 system,info verified ipv6-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of ipv6-5.7
jan/01/2002 09:00:01 system,info verified hotspot-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of hotspot-5.7
jan/01/2002 09:00:01 system,info verified dhcp-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of dhcp-5.7
jan/01/2002 09:00:01 system,info verified calea-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of calea-5.7
jan/01/2002 09:00:01 system,info verified advanced-tools-5.7-mipsbe.npk
jan/01/2002 09:00:01 system,error license does not support new version of advanced-tools-5.7
It is what it says. License doesn’t support upgrading to v5. Check what you have in these menus:
/system package print
/system license print
NAME VERSION SCHEDULED
0 routerboard 3.30
1 system 3.30
2 user-manager 3.30
3 hotspot 3.30
4 advanced-tools 3.30
5 ipv6 3.30
6 multicast 3.30
7 ntp 3.30
8 routing 3.30
9 dhcp 3.30
10 ppp 3.30
11 security 3.30
software-id: "xxxx-xxxx"
upgradable-to: v4.x
nlevel: 5
first, upgrade to v4.17, then see if you can upgrade to v5
Hi Normis
After upgrading seems it works but the CPU freeze to 100% but the packets in and out no problems
uptime: 3m13s
version: 5.7
free-memory: 225408KiB
total-memory: 257120KiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 680MHz
cpu-load: 100%
free-hdd-space: 460192KiB
total-hdd-space: 520192KiB
write-sect-since-reboot: 6612
write-sect-total: 24075195
bad-blocks: 0.3%
architecture-name: mipsbe
board-name: RB450G
platform: MikroTik
check menu: “/tool profile print” and see which process takes up CPU.
