Hi all!
Currently i’m using Mikrotik version 2.9.8 level4. I have problem in limiting the bandwidth per user in hotspot. I tried to do the “rate limit” in Servers Profiles. I put 900k = 900kbps. However, i’ve found out that this “rate limit” is limiting the bandwidth on “LAN-HOTSPOT”. How can i do the rate limit per user so that each user in the hotspot can at least get 512Kbps each? and how can i limit the P2P bandwidth to 128kbps per user in hotspot?
below is the printscreen of my hotspot config. thanks!
