in RouterOS there is a bandwidth test tool. But it is not a good idea to test from the router, you have to test through the router - from one pc to another. on our webpage you can find the BandWidth test for windows. Use that: http://www.mikrotik.com/download.html#Bandwidth_tester
I didnt want to open another post with same problem.
I want to limit bandwith just in local network WIFI we dont have internet. when I use simle queue id just affect wlan users against lan users, I mean that I cannot limit traffic between two wifi users.
My default forward option is on, can these simple queues be done somehow or I have to turn off forwarding and then firewall rule every user???
I work with a school and we have a high number of use on our network i we get 256/512 from our ISP ,when i use simple queues and gave each Pc 4/10kbps but the system couldnot browse well please what is the minimal bandwith that can cary a system thank
First of all you dont need all that uplink, why not reduce it to 128kbps and increase your downlink instead. If you can manage virus and worm activities on your network you wont need 256kbps uplink. I am using 512/2048.
To your simple queue for each system; try 16/32. Or you increase gradually then get a value that suits your need. Also make sure those systems are used for just surfing the net and not for playing audio or video online.
Oh thanks am in i did night so when i come to work this everning i will do it but please one more qustion how can i stop users from playing audio or video online.? can you still help
tell me one thing. everyone are saying taht to limit all computers on router is needed to write 192.168.0.0/24 but when i do speedtest i get it with no limits!
if i write 192.168.88.0/24 i get limit but is these limit for whole connection so everyone get just few of the limit or it’s limiting each by each user?
i have the same prb, the simple queue is limit only if i have the ip behind the 192.168.88.00 LAN. if i want to limit the IP in a separate interface the limit didnt work
