Hi all,
I just set up pppoe server at my MT, but still have one problem. I wouldd like to set up different max tx and rx per user. How to do it?
Regards.
Adi H.
p.s. ver MT 2.9.6
Hi all,
Regards.
Adi H.
p.s. ver MT 2.9.6
Use radius. MT doesn’t know over multiple sessions what the values of the tx and rx bytes are for sessions that was used previously
Ok, thanks. Which radius server you recommend me. I"d like to have gui. Its for freeBSD.
Regards,
Adi H.
Freeradius / Dialupadmin I guess…
What you want to achieve is not a standard configuration however, it requires massive amounts of work and customisations on the radius side unfortunately.
