is there any way to limit connections per one dst-address for each user?
example: each user can open maximum 10 connections to 1.2.3.4:80
Here ya go,
add action=drop chain=forward comment=“tcp connection limit”
connection-limit=100,32 disabled=no protocol=tcp
This is set to drop the 101rst tcp connection per ip address
you can modify it by specifying the destination IP and port to get really specific if you want.
yes, but i need limit connections to 10 per ANY dest-address
Be as specific or as not specific as you like. a 10 connection limit to any address would look like this:
connection-limit=10,32 disabled=no protocol=tcp
I should warn you that web browsing would be very difficult with that setting. Id suggest a minimum of 40 connections.
If you want to limit 10 connections to any IP on the following 192.168.3.0/24 destination network;
connection-limit=10,32 disabled=no dst-address=192.168.3.0/24 protocol=
tcp
thanks for answer
in general, i need limit total connections to 100 (from 1 user) and no more 10 per anyone dest-address
add action=drop chain=forward src-address=192.168.1.0/24 comment=“no more 100” connection-limit=10,32 disabled=no protocol=tcp
add action=drop chain=forward comment=“no more 10 per anyone” connection-limit=10,32 disabled=no protocol=tcp
is that right?
looks good to me.
