Acerko
1
Hello guys,
As you can see in subject my question is about connections per one user.
I use this code:
/ip firewall chain=forward in-interface=bridge protocol=tcp connection-limit=40,32 action=drop
With this code every user should be limited on 40 connections.
Is this good? Dont know how to check.
Anumrak
3
I think you should also assign src-address in IP from.
It"s depends on your network size and services running in your network
p3rad0x
5
You should be able to check more or less in the connection tracking table how many connections there are to any one give internal IP address.
gamba47
6
You can log your rule
/ip firewall chain=forward in-interface=bridge protocol=tcp connection-limit=40,32 action=drop log=yes log-prefix=drop
then look your logs for this line and check if it works.
Best regards.
gamba47
