Why RB750G is using 100% CPU when uploading with 30Mbps or more ? It happens when downloading with high speed of 60Mbps or more…All other connections being dropped or being very slow.
Can’t understand RB750G can’t handle 30Mbps upload or what ? And this a single connection upload, I’m not talking about torrents and stuff.
How to solve this High CPU issue ?
What config do you have? If you have bridge also then check so that your not sending the bridge traffic through the FW unless you need to. I would guess that with wifi, bridge, bridge FW, FW you would max out at around 40mbit on that hardware. The 750G has really limited CPU power
I’m not talking about gigabit, it should handle 100Mbps, I don’t want and need more.
And again it’s just a single connection through one provider, not multiple connections, at just 20Mbps upload, CPU load is 100%.
upload the main file routeros-mipsbe-5.11.npk, reboot. After reboot upgrade the firmware. If your using usermanager, hotspot or net time, then you need to upload them from the larger zip file too. I ususally do that after fw update.
