limit download for user and >>>>
how to limit download for user and when this limit is over the speed is down for user automatic not disabled for example : user speed 512 K B when limit is over the speed down 64 K B (on mikrotik hotspot)
i think this is you need http://wiki.mikrotik.com/wiki/Manual:Queues_-_Burst
no is it
Any body can help me please
thank you all …
I don’t even understand the question. The rate limits gets reduced on what trigger? What does “when the limit is over” mean?
sounds like that limit is in megabytes =) so user should get lower speed after downloading NNN MiB (per month?) on high speed
i think same with chupaka, maybe it also called “quota”. :slight_smile:
yes i mean that
please help me Chupaka >
your billing system should do that (RADIUS, or what you use). internal RouterOS means can’t limit speeds depending on downloaded amount of data
