Could anyone help on how to limit download speed but not normal internet browser?
In my corporate some users keep download video, movies, all night day, I want to limit just only download but not everything else.
Thanks,
Thanks,
hello.
generally, there are 2 common method in doing download limit
google: squid web proxy.
mikrotik help page: bandwidth management.
hope this helps.
In most corporate, users sign documents.
On said documents.
No change to config required.
It depends. If it’s regular download where one connection transfers a lot of data, you can mark it using connection-bytes, e.g. after 10MB:
/ip firewall mangle
add chain=forward connection-mark=no-mark connection-bytes=10485760-0 action=mark-connection new-connection-mark=bigtransfer
and then use queues to slow it down. Of course it’s far from perfect.
Create mangle rule which marks packet for some connection protocol ports (HTTP, FTP…) if connection bytes are above of some threshold, eg. 20Mb. Create queue and add that packet mark in lower priority than others.
Edit: Double post of same solution sry, I didn’t read carefully Sob’s answer above.
That approach can work, you can play with queue rules, you can hard limit such connections or just prioritize them.
