hi
anyone can help me with session limitation per 1 user ?
i m using pppoe .
i need some clients to limit their sessions to 30 only .
regards
hi
i m using pppoe .
regards
you can set limit to overal TCP connections per user,
‘/ip firewall filter add chain=forward protocol=tcp tcp-flags=syn connection-limit=31,32 action=drop’.
Note, p2p application can generate a lot of connection and it will influence user with TCP connection limit (in other words, when 30 connections are used by user, client will be unable to establish new connection[open web-page, etc.])
Skynoc.
for more information see :
http://www.mikrotik.com/testdocs/ros/2.9/ip/filter.php
but our clients they do not need more than 10 sessions at least .
Remember , our ISP or all our ISPs , they decided to give all their clients or restricted to 10 sessions … so that what makes this package to be cheap .
This package is only for 1 computer .
NB: This session limitation is only for TCP requests.
To only allow not more than 10 simultaneous connections from each of the clients, do the following:
/ip firewall filter add chain=forward protocol=tcp tcp-flags=syn connection-limit=11,32 action=drop
and for P2P , you can mark P2P connections and limit it .
Regards,
Ghassan
Its not work for me
I applied this to my routerOS, later I can still torch one user with more than 30 session going on
My network has 1 LAN interface, act as both PPPoE & Hotspot services
