Hello everyone.
Has there ever been a limit imposed on how many tests can run at once using the Traffic Generator?
I have seen that there’s a limit of numbers 0-25 which should mean a total of 26 tests. However I have found that the actual limit on my RB1100 is actually 16 total tests. So tests 0-15 will run even though 17-25 are also configured to run.
Is this some sort of capped soft limit?
Is it possible to increase this to be higher in ROS 6 to the limit of the processor?
