Limit of hotspot users on Cloud Core Router
Hello guys,
Is there any limitation of hotspot users on Cloud Core router?? on the wiki says that license 6 can have unlimited active hotspot users, but it is just allowing me to create 3000 users and not one more
Thanks for your help
Why do you want to create users on the mikrotik device?
I have 400 client (Not Much). they all running on a prepaid system with RadiusManager.
I use the hotspot function on my MT devices and all my authentication is done trough RadiusManager.
Check it at http://www.dmasoftlab.com
Just some advice. :slight_smile:
Hi Spri,
Well, it’s a university and the users and password are the same as the studentid and password, so the university has 12000 students.
Actually i can try with usermanager which is in the same mikrotik Platform, but i am wondering if is a limitation for how many hotspot users can i create on the users tab.
Thanks for your responses
