i got a wifi network using MT (433 etc) on my high sites and clients connect to it using UBNT products via PPPoE. All the towers connect to a central hub where goes out to the Internet.
Now what I want to do is the following:
1)Limit a client’s Internet bandwidth (already doing this using profiles under PPoE)
2) I got a server in my server room to which I want to give my clients full speed access. Meaning the bandwidth must not be throttled. Please keep in mind that the netowork is a routed network.
i don’t know much about ubnt, add second static route with static internal ip´s like 10.x.x.x/8
to your server, don’t user the PPPoE for this.
I duster this with my Voip, second Route to second Router, with different Internet Connection
Wan Interface IP-1 10.10.100.xxx/24 Route VOIP Mangled for there IP Adress you need
Wan Interface PPPoE IP -2 85.199.166.128/25 Route Main used for all normal Traffic
I don’t know if Airos can do this.
The PPPoE Limit only works on the PPPoE Interface, because the Access Concentrator does the Limit not the Client.
