Limit Some Connections Speed
hi all,
I’m using mikrotik, really it is so fine with me.
but now i need to limit some connections whitch destinied to some porn sites.
what i need is to let that connection to that site is soo slow, also when it show an online .flv file, that file will be so slow.
Really i need to that, i don’t need to make that site off of my network, because i don’t need to let the users know that i cause that problem.
what i need is to kill that connection by slow data rate.
thanks…
:laughing:
Use an external proxy such as Squid, with Delay pools.
Jimbo
or you can make “simple queue” to that specific IP of the server.
May please tell me how to make it step by step :smiley:
If you want to use a simple queue, then go to http://wiki.mikrotik.com/wiki/ and search on the term “simple queue”
If you want to do it via delay pools, google squid delay pools.
We can’t do it all for you now :slight_smile:
Jimbo
Thanks for all,
but what i need is to slow the connections that go to porn sites. :laughing:
so, how can i do that ???
if mikrotik do that …thats will be great .
the porn sites are dangers for our family , mankind and decencies ..
really we need to do some thing for these sickening web site .
if you can make a clear rule to define ‘porn site’…
