Limit SPEED of new TCP connections
I have been searching this forum for couple of hours and all I found is answer how to limit number of TCP connections. But this is not a good thing if you want to give your customers quality service.
Is there a way to limit max connections per second or minute?
If this was already answered just refer.
You could try a filter rule with protocol=tcp tcp-flags=syn,!ack
and put a limit=xxx or dst-limit=xxx restriction on that rule.
The tcp-flags=syn,!ack are indicating a new TCP connection setup, therefore no more new TCP connections can be established once the limit kicks in.
–Tom
Thank you Tom. I will try that.
