limit speed on bridging interface, how?
I have rb 153, 1 wlan and 5 ethernet interfaces. All of the interfaces are bridged. I want to limit speed on ether1. from queue that don’t work. Does someone know how can I limit speed via some interface?
It is impossible that u can’t limit. Maybe u can try this :
torch to ur interface bridge. if there is a traffic pass the interface, you can limit the traffic with simple queue
with the tool-torch, u can know the source and dest address, and that the ip you can limit
via that interface only that one user is connecting and I want to limit his speed. I don’t want to limit his IP, that’s no good for me, becouse his IP is changing every 24 Hours.
up
Probably, the following configuration example will help you,
http://wiki.mikrotik.com/wiki/TransparentTrafficShaper
