limit time user in hot spot in mikrotik v5.11
Dear support,
i setup hot spot in my mikrotik.
can u tell me how to limit time user in my hot spot , i want that one user can use only 3h only.
maybe this help
http://forum.mikrotik.com/t/free-hotspot-user-time-limitation/7697/1
also check the mikrotik wiki
you can install user manager package. go to mikrotik download page, choose to download all packages, open mikrotik thru winbox and just drop down the userman.npk into files tab. restart your router and voila you are done. you can access your user manager site at http://your-router-ip/userman
Use your default admin login with blank password
