I want to limit specific IP addresses to only browse a specific number of work-related websites/URL’s. Can someone suggest best approach to this?
Thanks in advance.
Shane
Thanks in advance.
Shane
Set up webproxy, then allowing and dropping specific sites is easy.
I have test MK Web proxy and works fine, but the problem is . . . .
I can bypass it with some programs like Ultrasurf ![]()
Then set up very strict firewall,that allows certain src addresses only to specific destination addresses.
Absolutely I did it!!!
Once I had a PPPoE server on V 4.x and redirected certain users that their credit was over to a page which tells them pay for recharge.
It works fine. but after a few days, I understood they bypass webproxy with Ultrasurf. It was a shame for our network!!!
