Hi All,
I am new to Mikrotik RouterOS, I would like to know how to limit Wi-Fi download and upload speed (bandwidth) from Winbox?
As I found the speed obviously decreased on wired devices when high usage on Wi-Fi devices (for example a big file downloading and almost consumed all my total bandwidth from ISP for a short period of time)
I searched in the forum, some posts mentioned it can be done by using “Queues”, but I do not want to add the client IP every time I have a new device connected with Wi-Fi, I want to do it on interface level, but seems I can only adjust the value of “Default AP Tx rate” and “Default Client Tx rate” in the interface “wlan1” config, and no Rx value can be defined.
May I know what is the best, easiest and correct way to limit download/upload bandwidth for the wlan1 interface?
Thanks.
Regards
