Limited channels for certain countries - Solved!
Noticed for 2.4GHz network for hap ac lite for some countries only 1-9 channels could be selected. I think that is wrong, for example in estonia 1-13 channels are allowed and i think that goes for the rest of the EU as well. Why the restriction?
Maybe you tried to set a wide channel like 80 MHz in Ceee mode and then it is correct that the highest channel number available is lower.
In Ceee mode the selected channel (C) would be 9 and the 3 extension channels eee would be 10, 11 and 12.
When you select eeeC mode you can select a higher channel number but then it will not be possible to select channel 1, 2 or 3.
nope 20 Mhz. Anyways it seems to be fixed now. Looks like the last update did the trick
I’m seeing this exact same thing, updated and running 6.46.6 everywhere.
I cannot for the life of me figure out why I can’t set (or even select) all of the channels on my 2.4GHz radio. See output below.
It’s set to united states3 as it should, hw-info shows the frequency range supports it, but allowed-channels doesn’t display everything.
[admin@anckerwap-3] > /interface wireless info hw-info wlan1
ranges: 2312-2732/5/b,g,gn20,gn40
2484-2484/5/b,g,gn20,gn40
tx-chains: 0,1
rx-chains: 0,1
extra-info: pciinfo:0x0, cid:0, gain:2
locked-countries: united states3,canada2
[admin@anckerwap-3] > /interface wireless info allowed-channels wlan1
channels: 2412/20-Ce/gn(28dBm),2417/20-Ce/gn(28dBm),2422/20-Ce/gn(28dBm),2427/20-Ce/gn(28dBm),2432/20-Ce/gn(28dBm),2437/20-Ce/gn(28dBm),2442/20-Ce/gn(28dBm)
