Limited speed on ext port
Gents,
I am using the following body:
Model 750UP
RouterBoard OS: 5.6
ISP has upgraded link to 20mbps, but when I try to test speed (speedtest.net) from various users PCes in LAN it gives maximum 8-10mbps.
Could you please advise where in microtik configuration might the bottle neck.
Any ideas would really be appreciated.
Thank you
The problem should be fixed if you update to version 6.x Ros
