Limiting a user to a given amount of traffic II
To try get this script working:
http://wiki.mikrotik.com/wiki/Limiting_a_user_to_a_given_amount_of_traffic_II
:local traf;
/queue simple
  :for i from=1 to= 254 do =  {
    :if ([/queue simple find target-addresses=("192.168.1." . $i)] != "") do={
      :set traf [get [find target-addresses=("192.168.1." . $i)] total-bytes]
      :if ($traf  > 104857600) do = {
        set [find target-addresses=("192.168.1." . $i)] max-limit= 32000/64000
Ive done the following:
  1. I created a simple queue:
/queue simple print
 0    name="queue1" target-addresses=172.18.88.192/28 interface=all parent=none
      packet-marks="" direction=both priority=8
      queue=default-small/default-small limit-at=0/0 max-limit=0/0
      burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
      total-queue=default-small
  1. Edited the script to match my subnet: (limits very low just to test) and added via Winbox
/system script print                                        Flags: I - invalid
 0   name="test" owner="test"
     policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,
       api
     last-started=nov/19/2012 21:35:11 run-count=22 source=
       :local traf;
         :for i from=192 to=206 do =  {
           :if ([/queue simple find target-addresses=("172.18.88." . $i)] != "") do={
             :set traf [get [find target-addresses=("172.18.88." . $i)] total-bytes]
             :if ($traf  > 1) do = {
               set [find target-addresses=("172.18.88." . $i)] max-limit= 1/1
  1. Scheduled the task to run every 1min (agian just to test for now)
/system scheduler> /system schedule print
Flags: X - disabled
 #   NAME   START-DATE  START-TIME   INTERVAL             ON-EVENT    RUN-COUNT
 0   sch... nov/19/2012 19:50:41     1m                   /system...          25
Yet the script appears to be having no effect. Have tried changing my simpe queue to just that of my current ip rather than the entire /28 subnet with no effect. (Have also checked others posts on the forum relating to the script)
Any pointers?
What version of RouterOS are you running? I think the example script you’ve found is from an older version, and there are other problems.
  1. The original script has syntax issues. There are a couple places where there should be no spaces. Example “:for i from=1 to= 254 do = {
  2. Also, the script won’t find the IP addresses unless a subnet mask is specified. In the simple queue, it might only show up as 172.18.88.50, but the script finds it as 172.18.88.50/32.
  3. Your final script is missing the /queue simple code at the top
Fixing these things worked for me on v5.14:
:local traf;
/queue simple
:for i from=192 to=206 do={
	:if ([/queue simple find target-addresses=("172.18.88." . $i . "/32")] != "") do={
		:set traf [get [find target-addresses=("172.18.88." . $i . "/32")] total-bytes]
		:if ($traf  > 200) do={
			:set [find target-addresses=("172.18.88." . $i . "/32")] max-limit= 1/1
 /system resource> print
    version: 5.22
  1. The original script has syntax issues. There are a couple places where there should be no spaces. Example “:for i from=1 to= 254 do = {”
In addition to your suggestions I tried changing “:for i from=192 to=206 do={” to “:for i from=193 to=206 do={” as 192 is the broadcast address.
Flags: I - invalid
 0   name="script1" owner="test"
       api
     last-started=nov/30/2012 01:23:19 run-count=4 source=
       :local traf;
       /queue simple
= "") do={
tal-bytes]
= 1/1
 /queue simple print
 1    name="queue1" target-addresses=172.18.88.192/28 interface=all parent=none
Tried changing simple queue target address to just that of my current IP:
/queue simple print
 1    name="queue1" target-addresses=172.18.88.205/32 interface=all parent=none
Still no result… :confused:
Is
Flags: I - invalid
an indication ROS isn’t happy with the script?
Sorry, I had a typo. There should not be a semi-colon before the last “set”
:local traf;
/queue simple
There might be another issue as well. The simple queues don’t seem to work for me when set to default-small. After I change to default (3 places), they work ok.
/queue simple print
      queue=default/default limit-at=0/0 max-limit=0/0
      total-queue=default
Thank you :smiley:
The network I intend to use this on is a /24
Is there a way to apply the script to a sigle simple queue with a /24 target address?
Or must a simple queue be created for each address on that subnet?
Simple queue for each IP is the only way I’ve been able to get it to work so far.
Yes. Change the script in 3 places:
:local traf;
/queue simple
   :if ([/queue simple find target-addresses=("172.18.88." . $i . "/24")] != "") do={
      :set traf [get [find target-addresses=("172.18.88." . $i . "/24")] total-bytes]
         set [find target-addresses=("172.18.88." . $i . "/24")] max-limit= 1/1
In addition I also changed
to include the broadcast ip after which it ran.
However it seems I’m still facing the problem of needing separate /32 simple queues for each user i want to limit.
I say this because when I run the script:
Flags: I - invalid
 1   name="/24" owner="admin" policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api last-started=dec/02/2012 13:24:46 run-count=18
     source=
       :local traf;
       /queue simple
       :for i from=0 to=255 do={
          :if ([/queue simple find target-addresses=("192.168.88." . $i . "/24")] != "") do={
             :set traf [get [find target-addresses=("192.168.88." . $i . "/24")] total-bytes]
                set [find target-addresses=("192.168.88." . $i . "/24")] max-limit= 65536/65536
against my simple queue:
 /queue simple print
  1    name="/24" target-addresses=192.168.88.0/24 interface=all
      parent=none packet-marks="" direction=both priority=8
      total-queue=default
and the limit get applied as it should:
/queue simple print
      queue=default/default limit-at=0/0 max-limit=65536/65536
      total-queue=default
All users regardless of how much they themselves have or haven’t used get throttled along with it. The script is limiting the subnet as a whole, not individual users.
Without creating separate /32 simple queue’s for each user on the subnet is it possible to limit only users who’ve exceeded their individual limits rather than the subnet as a whole?
The script is for a coffee shop that gives free wifi to customers after a purchase. They authenticate using a WPA2 key that gets changed by staff each morning. I’ve lowered the signal strength to try cover just the shop space but the system is (not surprisingly) still being abused.
I don’t know how you would track each individual’s limits without separate queues.
Have you used the hotspot feature in the RouterOS? I wonder if it might be helpful for what you are doing. You can configure default rx/tx rate limits for hotspot users, and a new dynamic queue is created for each one. With the individual queues in place, you could use a script to loop through all hotspot queues, check bytes and change the queue accordingly.
There could be other ways to do this, but the hotspot setup is the only one I’m familiar with.
Havn’t tried Hotspot / Usermanager yet. (Want to limit staff having to do anything more than changing WPA2 key daily if possible)
Ended up creating a /27 LAN subnet (DHCP lease of 3hours) with 29 simple que’s.
script1 every 2.5 minutes limiting users to 75/75kbps if they exeed a 100mb total.
script2 every 2.5 minutes (after script1) limiting users to 10/10kbps if they exeed 125mb total.
script3 every 4 hours (after script1,2) resets all users with totals over 1kb back to 4mbps.
script4 every 4 hours (after script 1,2,3) resets all users with total of 0 back to 4mbps (rb reboots leave limited users limited otherwise)
script5 every 4 hours (after script1,2,3,4) resests all counters. (/que simple reset-counters) but doesnt reset limits hence script3,4
Still checking on it every 8 hours or so but for most part seems to be working.
Is open to abuse by users giving themselves (as yet not limited) static IP’s (rinse repeat)
But better than no limiting at all for now.
Thanks again :slight_smile:
You could set the arp to “reply-only” on the AP interface, which will ensure that only DHCP issued addresses are allowed to operate. Will block all non-DHCP addresses.
[*]I got an error, take a look please
[/color]
paste the script into the script editor, not the console command line
