Is there any way to limit the number of wireless connection per radio to say 50 to prevent a single access point from getting overloaded?
thank you
If you want to limit the max registered clients, just set the number on the wireless interface…
Where is this setting. I cant seem to find it
Thank you
Under the interface properties (in winbox) click advanced and its the field labeled: MAX-STATION-COUNT
