I am an owner of MIKROTIK RB3011UIAS-RM. To the router is connected Dell N1548 switch, which works in bridge mode (On interface list it is visible as type - bridge)
Every user in my network is connected to this switch. Due to slow internet connection and often issues with internet my goal is to limit the internet connection speed to 1 mbps on selected ip’s and in selected dhcp pool - for instance 10.2.0.20-10.2.100 and 10.2.0.117. I see every desired ip on ARP list. I tried to limit the internet speed of my computer (10.2.0.117) - i used Queue bookmark - but it seems like the settings doesn’t work for me.
Is this possible to do ? (i realize that bandwitch control can be more complex but at start i want to set the constant limit to every device). Are there some scripts to achieve that quick, could i obtain any hint ?
Regards,
Jaromir
