Limiting SMTP Port 25 on my Network
Is there a way to limit of using SMTP in my IPs? So we are trying to create Firewall Raw rules with the following config.
IP Firewall Raw
Chain: prerouting
Src-Address-List: !Whitelist-SMTP (So I create address-list to whitelist SMTP)
Protocol: TCP
Source Port: 25
Action: Drop
But eventually, all incoming and Outgoing SMTP are being blocked. Im planning only to block for spammers to use our IP Address as SMTP Mail Relay.
Secondly, can I limit all email send out? For example 50 email per hour for every IPs?
Thank you very much for all advice…
Sincerely,
Hernan
Hi there
Can you send the command you created?
/ip/firewall/raw/export
/ip/firewall/address-list/export
Regarding limiting the number of email per hour per IP, not that I know of in the default configuration. The Mikrotik has a pretty basic firewall and in no case something that does DPI/L7 inspection well. For that, you will need the equivalent of an SMTP gateway.
