anybody had success with limiting speeds about 50 mbps(pcq-rate=50m) using pcq+queue tree shaping ?
In my particular case, I have not tried with this bandwidth. But it should work correctly!!!.
regards
i cant reach this speed with pcq.a set pcq rate to 55m and cant reach 25 mbps.mikrotik answered that this is pcq bug and they can`t do anything with this.
simply increase ‘Limit’ and ‘Limit Total’ parameters of pcq. higher speeds need longer queues
chupaka:
can you tell me values for limiting 72 user at speed 55 mbps.
I think, it depends on packet rate. I simply checked with default settings (got ~25-30 Mbps) and then with Limit=500, Total-Limit=20000 - and saw honest 50 Mbps of traffic
tryed with these values and cant get these speeds.With b-test from pc to router i can reach 100 mbps, from router to world - 1gbps, but i cant reach 50 mbps using pcq.chupaka, what hardware do you use?
I’m using x86 (something like Core2Duo 2333 MHz), ROS v4.1
same hardware, cpu core 2 duo e2200, intel 82572EI cards.
mine is 82566DM-2 =)
can you post your config?
I just added a queue and marked all packets to my computer. just changed PCQ parameters…
