I’m having problems with bandwidth-hogging users on our satellite internet connection.
The current biggest issue seems to be people using “download accelerators”. Some component in the system (probably the V-SAT modem) seems to share bandwidth equally between all connections. So if you’re using a download accelerator (opening lots of connections) you get all the bandwidth and everyone else starves.
Our acceptable usage policy forbids the use of download accelerators but I’m getting fed up of going round checking users’ PCs and uninstalling them.
I can see that it’s possible to limit connections per IP address, but I’m worried this might cause problems for innocent users.
So, is it possible to just limit the number of connections each IP address on our network can make to a single internet IP? For example, if our user 192.168.0.71 is trying to open 20 connections to 208.65.153.253 can we limit it to 5 connections?
What would be a good limit for the number of connections from one local IP to an internet IP?
Doesn’t that just mean that each local IP address only gets allowed 5 connections total, I was wanting to limit it so that they could have (for example) 5 connections to one internet IP, 5 connections to another, …
