Limits on IPsec/L2TP VPN connections on level 6 license
Hi Guys,
I have a IPsec/l2tp VPN for my remove users… i am using a CCR1006 router with level 6 license.
When i have more than 3 users connecting to the VPN the last previous user gets disconnected….
I have 2 sites and can confirm this issue happens on both routers.
Both routes are running v6.40.2 firmware
Is there some kind of limit on the license? or somewhere in the config that this limit is set? i have searched forums and config and can’t find anything…. the only thing i can think of is the license, but this level 6 license should have unlimited number of l2tp connections?
What’s on System > License?
It doesn’t have to be related to license, there are other settings that may cause this, like bad ip pool, inconsistent settings, etc.
Watch out the log when that happens, and post it here. Posting an export of your config is a good idea also.
