Hi every one,
I want to know if enyone could help me to Limit Nated Traffic from my users’ Network.
I give each of my users 512kb/512kb
Sometimes its connections number become very larg. I can only Serve home users, please help me to solve this great problem.
How much traffic is given on this link ?
How many users are using this ?
Probably you may try with PCQ to divide traffic available between all users equally
Thanks For Reply
But I have already done that setup
I have Queue Tree with PCQ Type
And I give my users equally traffic but I want my users don’t use NAT Can You help me ???
I do not know what kind of NAT rule is used now, specify subnet for masquerade rule or add action=accept for the specific src-address before NAT rule to exclude them.
Make sure that this client uses routeable IP address, that is reached over the world.
But it will not help you, if you link is congested, you need to improve QoS settings then (or increase capacity of the link, if it is not enough).
Thanks For Attention
So I have such setup for my Router
/ ip firewall nat
add chain=srcnat src-address=172.16.0.0/12 action=masquerade comment="" disabled=no
User whos VPN IP Adress is 172.17.8.25 is using NAT for his purpose On his side, on his own router but we havn’t any agrees to give User to use internet and nat it for others
Can I have some firewall rules to limit or to Drop the packet that are Nated by my User who Had not do such things
With Regards K. Aznavuryan
To avoid your clients to use NAT, you can try setting TTL to the value that will expire meaning reach value of 0 after the host IP, this means that after your host nothing will work.
Regards.
Faton
Thanks To All Very Much
I’ll try and tell you the result of my experiments ![]()
Faton Thanks for advise
I tried But there was no result
Look at my experiment’s result
when I set the TTL to 64 or smaller to 8 I see
C:\Documents and Settings\Karo>tracert www.mikrotik.com
Tracing route to mikrotik.com [12.22.39.145]
over a maximum of 30 hops:
1 487 ms 492 ms 485 ms a039145.colo.fsr.net [12.22.39.145]
Trace complete.
But when TTL is smaller than 11 I receive reply from the 11-th hop or if TTL is 3 I receive reply from 3-rd hop
At all this time my TCP connections were working very well, I didn’t see any difference.
Some Advise or something else???
just adjust ttl in your access router, set ttl in mangle and decrement it to 2 so this means that if you receive a packet with ttl 30 it will decrement it to 2 than next hop will be 1 (your client) and after that it will expire.
Regards.
Faton
P.S. I have done it and it works.
Thanks Very Much
